Hi everyone, I have a WHS2011 server with 8 active pool drives. I have one drive that's very old and I don't trust. I'm using the add-on balancer "File Placement Limiter" and it's the top priority. I've told it not to store unduplicated files on this drive. The little red arrow shows my setting of "Unduplicated file placement limit 0.0%", however it's currently balancing and shows an unduplicated target of 108GB of files to this drive. I have never been able to get it to adhere to these rules. The other day I had a drive develop SMART errors and I have the "StableBit Scanner" balancer as second in priority and have requested that unduplicated data be moved off of drives with SMART errors. It showed it with the same unduplicated file placement limit, but again didn't do anything with my unduplicated data on the drive. I'm not sure why it won't follow these rules.
Synopsis:
File Placement Limiter balancer as top priority balancer. Specific drive told not to store unduplicated data. Drive balancer shows a limit of 0.0% for unduplicated files, yet it is storing unduplicated files on it, and adding more.
Stablebit Scanner balancer second in priority, with the rule enabled to move unduplicated data out of drives with SMART errors. Drive with a SMART error shows the same 0.0% limit for unduplicated files, yet no unduplicated files are being removed.
Disk Space Equalizer is enabled as a third priority balancer set to equalize by percent used, using both duplicated and unduplicated files.
Drive Pool version 1.3.5.7572
StableBit Scanner version 2.4.2929.
Any ideas?
I've attached a screenshots of the Disks page showing the balancing, and also the various active balancers and their settings. NOTE: I've removed the drive with SMART errors as it is truly going bad. The drive I've set for no unduplicated files is listed as Internal 3 (N:).
dtgoodwin 0
Synopsis:
Any ideas?
Thanks
Doug
9 answers to this question
