So, one of my 3TB drives from my 53TB pool is failing (showing flashing red X on HDD Sentinel), I have a lot of unused space on the pool, approx 11TB. So I have a few drives in the pool with only a few GB on. Instead of buying a new 3TB drive is there any way for me to move off the data off a little used drive in my pool, and then also move across all the 3TB of data from the failing drive on to that drive ? What actually happens if I manually move data in the hidden pool folder to another pool folder on another drive ? Any suggestions on how best to do this ?
Here is an example of what I mean (poolpart numbers are random, not real).........
Drive1 = PoolPart1342343 - Failing 3TB drive, it is 2.62TB used.
Drive2 = PoolPart324343 - 4TB drive only has 100gb on.
Drive3 = PoolPart4534534 - 4TB drive, plenty of space on
So if I were to copy the 100gb from Drive2 to Drive3, leaving Drive2 empty, and then copy all of Drive1 on to Drive2. If so what is the safest method to do this ? Would it automatically keep everything in order ?
Also, the drives are SnapRaided, would it be safer to copy everything off and hope everything is in tact data wise, or restore from the parity drive ?
Zammo
Thanks !!
