Adding drive with existing files to stable bit
Is this possible? I created my first pool and went to add a drive with files on it...it added the drive, but the files where nowhere to be found
Was there an extra step I missed?
As Umfriend says, adding a drive to the pool doesn't add any files that are already on that drive to the pool - those files stay where they are. You can do the seeding Umfriend describes or you can simply "cut and paste" them from the physical drive to the pool drive (less work for you, more work for your drives, and requires enough "free" space on the pool).
Either way just be sure you don't copy any PoolPart.* folders from the physical drive into the pool.
