My feeder disk (WD Black 750GB) has a bad sector and some SMART warnings under Stablebit Scanner, so has been marked as damaged.
Drivepool figure that out and start moving the data automatically.
This started 2 days ago, and is not finished yet...
I then try something else: I am deactivating the balancer for the scanner, to stop auto balancing; then reboot the server; then click on remove disk under DP.
DP works a while analysing the disks (it refreshes the usage stats), then stops not doing anything.
Checking the logs, seems that some files cannot be moved (check the log file attached).
Checking the logs for previous balancing operation, seems that a lot of files cannot be moved because of bad permissions.
Where does that come from?
I am not using the DP disks directly in any way, just through DP; so I cannot have modified the permissions on the DP folders myself.
Thank you for any help, I need to remove that disk to send it to WD for warranty.
DrParis
Hi there,
Back with some new troubles
DrivePool.Service-2014-02-10.txt
