I've got a similar issue to a few others: my 16TB Google Drive CloudDrive is showing up in Scanner as "File System Damaged". I can still access files on the drive, so I'm moving everything over to an identical CloudDrive. Chkdsk reports the filesystem as RAW and fails out, same thing with Scanner (which I assume just calls chkdsk). Is there anything else I can do?
Digmarx
24 answers to this question
