GreigH Posted March 27, 2017 Posted March 27, 2017 I'm having a problem getting the DrivePool user interface to connect to the backend service. This is on a Win 10 machine that has recently had some fast ring updates. It had been working fine. Any suggestions? I'm a new DrivePool user. Thanks. Greig Quote
0 Spider99 Posted April 5, 2017 Posted April 5, 2017 Fast ring are IIRC something like nightly builds of the latest updates for win 10 Any errors details available? Quote
0 Christopher (Drashna) Posted April 10, 2017 Posted April 10, 2017 Ugh, fast ring..... Likely, something in .NET broke. And if that is the case ... we can't do much. Try reinstalling the software and see if that helps. Otherwise, try running the StableBit Troubleshooter http://dl.covecube.com/Troubleshooter/StableBit.Troubleshooter.exe Quote
GreigH
Thanks.
Greig
