triadcool 15 Posted January 17, 2017 Share Posted January 17, 2017 I created a ReFS drive on version .802 of Cloud Drive and it seems that the pinned data won't go above 420KB. Is this normal for a ReFS drive or is something wrong? I only ask because of the poor performance when browsing files. Quote Link to post Share on other sites
0 Choruptian 1 Posted January 17, 2017 Share Posted January 17, 2017 .630* Added the ability to create ReFS cloud drives.- ReFS drives can be created starting with Windows 8 and newer (both in client and server editions).- ReFS drives cannot be attached to OSes older than Windows 8.- ReFS volumes can be up to 1 PB in size (and are not limited to 256 TB like NTFS). The 1 PB limit is the maximum drive size in StableBit CloudDrive and is not aReFS limit.- The metadata pinning engine cannot yet pin ReFS directory entries. I can't find anything more about this in the changelogs so I'll hazard a guess and say it's not yet supported. Quote Link to post Share on other sites
0 steffenmand 60 Posted January 17, 2017 Share Posted January 17, 2017 ReFS doesnt support pinning yet! Quote Link to post Share on other sites
0 triadcool 15 Posted January 17, 2017 Author Share Posted January 17, 2017 I'm glad it isn't an issue with my drive! Thanks guys. Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted January 21, 2017 Share Posted January 21, 2017 Yeah, ReFS doesn't support pinning, at this time. The problem is... we have to know the file system's data structure so we know what we need to pin. This means that we need to find GOOD documentation, source code, or reverse engineer the file system. The plus side.... we'll have ReFS Support in CloudDrive, Scanner and DrivePool (full support) at about the same time. tcz06a 1 Quote Link to post Share on other sites
triadcool 15
