WBadminUser 8 Posted July 21, 2016 Share Posted July 21, 2016 Title. Quote Link to post Share on other sites
0 steffenmand 60 Posted July 21, 2016 Share Posted July 21, 2016 set upload threads to 0 Quote Link to post Share on other sites
0 triadcool 15 Posted July 21, 2016 Share Posted July 21, 2016 I keep seeing people say that you need to set upload threads to 0 to stop any uploading. This information is incorrect. You can't actually set the upload threads to 0. You will need to uncheck the "Upload threads:" box. Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted July 22, 2016 Share Posted July 22, 2016 I keep seeing people say that you need to set upload threads to 0 to stop any uploading. This information is incorrect. You can't actually set the upload threads to 0. You will need to uncheck the "Upload threads:" box. Depends on the specific version. It was just setting it to 0, but that was changed to make it easier/more intuitive. Title. Just remember that you cache will continue to grow and grow as you add content. Once you've filled the cache drive, you won't be able to write to the disk anymore. Additionally, you can also set the max upload bandwidth, if that's the issue. Quote Link to post Share on other sites
0 WBadminUser 8 Posted July 22, 2016 Author Share Posted July 22, 2016 This worked guys. Thx! My use case was i was moving files onto the drive then extracting them. Just worked into my workflow better. But i didn't want to uploaded the compressed files re-download them to extract them then upload the extracted files. Christopher (Drashna) 1 Quote Link to post Share on other sites
WBadminUser 8
Title.
