mayorville Posted June 28, 2023 Share Posted June 28, 2023 I have 3 SSD's that I have selected as SSD in DrivePool. When I reboot, it has those same SSD selected as Archive. Quote Link to comment Share on other sites More sharing options...
1 Shane Posted June 28, 2023 Share Posted June 28, 2023 Could be a file permissions issue? Maybe check if other balancers are also not keeping changes? The config folder is "C:\ProgramData\StableBit DrivePool\Service\Store\Json" If you're unable to spot anything different, I'd suggest opening a ticket to report it. Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted June 28, 2023 Share Posted June 28, 2023 It definitely should be saving the settings. If you're still running into this, please open a ticket at https://stablebit.com/contact so we can get this sorted Quote Link to comment Share on other sites More sharing options...
mayorville
