  • Create Account
Help with Drive Pool
WHS2011 lost shares
  • Please log in to reply
6 replies to this topic
#1 bobbyc
bobbyc
  • Members
  • Pip
  • 1 posts
Posted 10 March 2014 - 06:40 PM
I installed a new drive in my WHS 2011 box.  As a result, my WHS Shares disappeared.  The new drive hijacked the Drive Pool's Drive letter.  Originally Drive Pool was the G drive, now it is the J drive.  When I log onto the server and open win explorer, all of the files for the pooled shares are present.
How do I fix the problem, and keep it from reoccurring?  Should I name the Drive Pool drive deeper in the alphabet?  Thanks for help.
  • Tardas-Zib likes this
#2 Doug
Doug
    Advanced Member
  • Members
  • PipPipPip
  • 63 posts
  • LocationUSA
Posted 10 March 2014 - 07:25 PM
This is very common, this post should help you.
#3 Christopher (Drashna)
  • Administrators
  • 8,394 posts
  • LocationSan Diego, CA, USA
Posted 10 March 2014 - 08:42 PM
bobbyc,
This is why we generally recommend manually changing the drive letter to something not commonly used.
For instance, Y:\ or B:\. Neither of these are used often and should be available. In fact, Windows should never attempt to use B:\ normally, so it's a great letter for DrivePool.
  • bobbyc likes this
Christopher Courtney
aka "Drashna"
This is my server
#4 Ryo
Ryo
    Advanced Member
  • Members
  • PipPipPip
  • 251 posts
Posted 13 January 2015 - 06:13 AM
Ive been setting my pool as the A: drive.... beats a 3.5 floppy LOL
#5 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 13 January 2015 - 10:32 PM
Just a heads up, setting the pool to A:\ or B:\ may cause the system to keep the disks in the pool awake, as Windows constantly "pings" these drive letters (hard coded behavior).
aka "Drashna"
This is my server
#6 Ryo
Ryo
    Advanced Member
  • Members
  • PipPipPip
  • 251 posts
Posted 14 January 2015 - 01:58 AM
thanks for the heads up
#7 Christopher (Drashna)
  • Administrators
  • 8,394 posts
Posted 14 January 2015 - 11:31 PM
Not a problem.
If you're not worried about this, then it's fine.
Personally, I don't care (solar power FTW), so it's not a big deal. But we did have a ticket about this a while ago. And it does seem that Windows has hard coded behavior for this.
However, that said, IIRC, Windows 10 is supposed to drop floppy drive support, which means it should not have this issue.
aka "Drashna"
This is my server
Also tagged with one or more of these keywords: WHS2011, lost shares
