I have pool of 5x WD 4TB drive array - a single ~18-ish TB array total.
While switching OSs (Windows Server 2016 to Windows 10 1903) on the system drive, I somehow managed to lose two of the drives (Drive 1 and 3) in the array. Stablebit Scanner showed the drives as having a corrupt file system but are otherwise healthy.
Drivepool showed the two drives as part of a different "phantom" pool that was not accessible with a corrupted file system. I removed these two drives from the phantom pool.
Windows disk manager shows the two drives as healthy. If I assign each of the two drives a drive letter in Windows disk manager and then look at how much space is used / free on the two drives in Windows Explorer, it is consistent with what it would have been when it was part of the 5 drive array.
Windows "repaired" the drives but only a zero byte file shows on each of those two drives in Windows File Manager. The file names are:
The two drives are currently not visible in Drivepool to add back to the array.
Presumably I could wipe the partitions and add them back to the array but I'd rather not lose the data if possible - not all of it was duplicated on the remaining three drives in the array.
Any suggestions on how the file system could be rebuilt enough to recover the data?
feeble
