  • 1
[Bug?] Prior scan data and settings not preserved on update
My server picked up on the newest version of Scanner this morning (2.5.3.3191), so I let it auto-update.  At the same time I decided to run a manual update (download/install) on my primary workstation.  Both completed successfully, but both also ran into an issue.  None of the prior scan data (either file system or surface) was preserved - all drives that both copies of scanner monitors on each computer were reset to unscanned.  I manually marked all unchecked blocks good, but some people may not know how, or want their old data/schedule preserved.
Server is running W7 Ultimate 64-bit (SP1), workstation is running W10 64-bit v1709 (build 16299.431).
Just updated from 2.5.5.3293 to 2.5.6.3336 and lost my scan history.  All disks were waiting to be scanned again.  My scanner settings window was open when I ran the installer if that helps any.
Thanks,
- Edirol
