arkx82 Posted July 14, 2017 Posted July 14, 2017 OS : Windows server 2016 Cloud drive : Google I did reboot PC. and I encounter this error "Drive mount Error" - Http status InternalServerError Would you please help me..? what can I do.. I did retrying.... so long time... chcguy88 1 Quote
0 chcguy88 Posted July 14, 2017 Posted July 14, 2017 I am having the same issue. I can't unlock nor can I remount an existing drive. Mine says "Internal error". Quote
0 Christopher (Drashna) Posted July 14, 2017 Posted July 14, 2017 open a ticket at https://stablebit.com/Contact And if you could, do this: http://wiki.covecube.com/StableBit_CloudDrive_Web_Logs That said, the "Internal Server Error" is an HTTP 500 error. This means that there is a server side issue here. As in, Google Drive is coming back with errors. In this case, there isn't much that the software can do, other than wait and retry. Quote
0 srcrist Posted July 14, 2017 Posted July 14, 2017 open a ticket at https://stablebit.com/Contact And if you could, do this: http://wiki.covecube.com/StableBit_CloudDrive_Web_Logs That said, the "Internal Server Error" is an HTTP 500 error. This means that there is a server side issue here. As in, Google Drive is coming back with errors. In this case, there isn't much that the software can do, other than wait and retry. To be clear, Christopher--and I mentioned this in the other thread--the problem here is that, during the reindexing process, it simply *doesn't* retry. Retry would mean that it puts in a request for chunk 2,345,234, gets a server error, waits, and puts in that request again. Instead, it puts in a request for chunk 2,345,234, gets a server error, and restarts at chunk 4,234,122--slowly working its way back down. It needs to retry, rather than abort and start over. In some cases, it doesn't even start over. It just fails, the UI gives a mounting error, and it sits there until you press the "retry" button. This behavior, of course, adds even MORE time to the process. The good news, for the other folks in this thread, is that the data on my drive was, ultimately, completely fine when this was happening to me. It will EVENTUALLY remount, and all of your data will be there. It can just take an entirely unreasonable amount of time. Quote
0 Christopher (Drashna) Posted July 25, 2017 Posted July 25, 2017 Okay. I do believe that I've bugged this behavior already, so Alex will take a look into it. Also, Alex has reworked some of the download code, so it may help with this. As for the retry, it does. however, after too many errors in a short period (120 seconds), the drive unmounts. The reason for this is that Windows is very sensitive to IO problems. So the choice here is wait and let Windows hang (this was happening a lot, when issues were occurring, causing system instability), or to disconnect the drive. Neither is great, ut we choose system stability over functionality. As for auto-retrying, it would not fix this issue. Addressing the root cause would be better in the long term, though. Even if that's adding special handling for indexing. Either way, we do appreciate the feedback. Quote
0 srcrist Posted July 26, 2017 Posted July 26, 2017 Christopher, To be clear: Are you saying that it is retrying multiple times even though the service log only records one error? Because I can see where it retries when the drive is actually mounted, but only a *single* server error needs to show up in the logs during the indexing process in order for it to completely restart the process. I'll paste you an example: CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] chunks IDs: 2067212,2067217,2067218,2067219,2067220,2067221,2067222,2067223,2067224,2067225,2067226,2067227,2067228,2067229,2067230,2067231,2067232,2067233,2067234,2067235,2067236,2067237,2067238,2067239,2067240,2067241,2067242,2067243,2067244,2067245,2067246,2067247,2067248,2067249,2067250,2067251,2067252,2067253,2067254,2067255,2067256,2067257,2067258,2067259,2067260,2067261,2067262,2067263,2067264,2067265,2067266,2067267,2067268,2067269,2067270,2067271,2067272,2067273,2067274,2067275,2067276,2067277,2067278,2067279,2067280,2067281,2067282,2067283,2067284,2067285,2067286,2067287,2067288,2067289,2067290,2067291,2067292,2067293,2067294,2067295,2067296,2067297,2067298,2067299,2067300,2067301,2067302,2067303,2067304,2067305,2067306,2067307,2067308,2067309,2067310,2067311,2067312,2067313,2067314,2067315 2017-07-04 07:50:02Z 209022985613 CloudDrive.Service.exe Warning 0 [ApiGoogleDrive:26] Google Drive returned error (internalError): Internal Error 2017-07-04 07:50:07Z 209039853973 CloudDrive.Service.exe Warning 0 [ApiHttp:26] HTTP protocol exception (Code=InternalServerError). 2017-07-04 07:50:07Z 209039867036 CloudDrive.Service.exe Warning 0 [CloudDrives] Cannot start I/O manager for cloud part 62179051-cb2c-46b8-818d-4ee2a186e3ec. Internal Error 2017-07-04 07:50:07Z 209039897780 CloudDrive.Service.exe Information 0 [CloudDrives] Synchronizing cloud drives... 2017-07-04 07:50:10Z 209048101740 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: a439b0c4-9e85-42a7-bccc-01ed3ff606dd, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:13Z 209058284693 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: c5c2798c-a82e-420b-97c2-0bd1f6740b75, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:13Z 209058286325 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: be624dce-5691-42a7-b43a-0ebc2693e4c7, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:13Z 209058286790 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: 57d7cdea-d18a-47e2-a3d1-40012094e450, Name: Covecube Virtual Disk, Adaptor: Covecube Cloud Disk Enumerator, Device path: \\?\SCSI#DiskCOVECUBECloudFs_________0001#1&2afd7d61&0&{53883972-f0d3-45bf-897d-8d8cb951cbb2}#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:13Z 209058287247 CloudDrive.Service.exe Warning 0 [ChunkIdHelper:26] Chunk ID storage engine does not have all the chunk IDs. Enumerating chunks... 2017-07-04 07:50:13Z 209059088095 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] Clear all chunk IDs... 2017-07-04 07:50:13Z 209059088767 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: a439b0c4-9e85-42a7-bccc-01ed3ff606dd, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:14Z 209059949614 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: c5c2798c-a82e-420b-97c2-0bd1f6740b75, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:14Z 209059951785 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: be624dce-5691-42a7-b43a-0ebc2693e4c7, Name: INTEL SSDSC2BB160G4, Adaptor: Standard SATA AHCI Controller, Device path: \\?\scsi#disk&ven_intel&prod_ssdsc2bb160g4#4&15828421&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:14Z 209059953983 CloudDrive.Service.exe Information 0 [Disks] Got Disk_Modify (Disk ID: 57d7cdea-d18a-47e2-a3d1-40012094e450, Name: Covecube Virtual Disk, Adaptor: Covecube Cloud Disk Enumerator, Device path: \\?\SCSI#DiskCOVECUBECloudFs_________0001#1&2afd7d61&0&{53883972-f0d3-45bf-897d-8d8cb951cbb2}#{53f56307-b6bf-11d0-94f2-00a0c91efb8b})... 2017-07-04 07:50:14Z 209059955406 CloudDrive.Service.exe Information 0 [Disks] Updating disks / volumes... 2017-07-04 07:50:15Z 209063279396 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] Set chunks IDs... 2017-07-04 07:50:19Z 209076555738 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] chunks IDs: 11,139,142,1856284,2797743,2797744,2797745,2797746,4210125,4210126,4210127,4210128,4210129,4210130,4210131,4210132,4210133,4210134,4210135,4210136,4210137,4210138,4210139,4210140,4210141,4210142,4210143,4210144,4210145,4210146,4210147,4210148,4210149,4210150,4210151,4210152,4210153,4210154,4210155,4210156,4210157,4210158,4210159,4210160,4210161,4210162,4210163,4210164,4210165,4210166,4210167,4210168,4210169,4210170,4210171,4210172,4210173,4210174,4210175,4210176,4210177,4210178,4210179,4210180,4210181,4210182,4210183,4210184,4210185,4210186,4210187,4210188,4210189,4210190,4210191,4210192,4210193,4210194,4210195,4210196,4210197,4210198,4210199,4210200,4210201,4210202,4210203,4210204,4210205,4210206,4210207,4210208,4210209,4210210,4210211,4210212,4210213,4210214,4210215,4210216 2017-07-04 07:50:19Z 209078418489 CloudDrive.Service.exe Warning 0 [ApiGoogleDrive:106] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded 2017-07-04 07:50:19Z 209078588436 CloudDrive.Service.exe Warning 0 [ApiHttp:106] HTTP protocol exception (Code=ServiceUnavailable). 2017-07-04 07:50:19Z 209078598915 CloudDrive.Service.exe Warning 0 [ApiHttp] Server is throttling us, waiting 1,236ms and retrying. 2017-07-04 07:50:19Z 209078599786 You can see, here, that it only got a single server error before deciding to enumerate the chunks again. It was at roughly chunk number 2067212, it gets the error, and then it starts over again at chunk number 4210125. As far as I can tell, there are no successive server errors in this log. Just one. One was all it took to restart the process. Here is another, even simpler, log snippet from a different occasion of the same situation: CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] chunks IDs: 1008805,1008806,1008807,1008808,1008809,1008810,1008811,1008812,1008813,1008814,1008815,1008816,1008817,1008818,1008819,1008820,1008821,1008822,1008823,1008824,1008825,1008826,1008827,1008828,1008829,1008830,1008831,1008832,1008833,1008834,1008835,1008836,1008837,1008838,1008839,1008840,1008841,1008842,1008843,1008844,1008845,1008846,1008847,1008848,1008849,1008850,1008851,1008852,1008853,1008854,1008855,1008856,1008857,1008858,1008859,1008860,1008861,1008862,1008863,1008864,1008865,1008866,1008867,1008868,1008869,1008870,1008871,1008872,1008873,1008874,1008875,1008876,1008877,1008878,1008879,1008880,1008881,1008882,1008883,1008884,1008885,1008886,1008887,1008888,1008889,1008890,1008891,1008892,1008893,1008894,1008895,1008896,1008897,1008898,1008899,1008901,1008902,1008903,1008905,1008906 2017-07-05 05:37:37Z 179431003884 CloudDrive.Service.exe Warning 0 [ApiGoogleDrive:26] Google Drive returned error (internalError): Internal Error 2017-07-05 05:38:06Z 179525435228 CloudDrive.Service.exe Warning 0 [ApiHttp:26] HTTP protocol exception (Code=InternalServerError). 2017-07-05 05:38:06Z 179525436540 CloudDrive.Service.exe Warning 0 [CloudDrives] Cannot start I/O manager for cloud part 62179051-cb2c-46b8-818d-4ee2a186e3ec. Internal Error 2017-07-05 05:38:06Z 179525503627 CloudDrive.Service.exe Information 0 [CloudDrives] Synchronizing cloud drives... 2017-07-05 05:39:57Z 179895055905 CloudDrive.Service.exe Warning 0 [ChunkIdHelper:26] Chunk ID storage engine does not have all the chunk IDs. Enumerating chunks... 2017-07-05 05:39:58Z 179898074584 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] Clear all chunk IDs... 2017-07-05 05:39:58Z 179898075210 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] Set chunks IDs... 2017-07-05 05:40:06Z 179923605343 CloudDrive.Service.exe Information 0 [ChunkIdSQLiteStorage:26] chunks IDs: 11,139,142,1856284,2797743,2797744,2797745,2797746,4210125,4210126,4210127,4210128,4210129,4210130,4210131,4210132,4210133,4210134,4210135,4210136,4210137,4210138,4210139,4210140,4210141,4210142,4210143,4210144,4210145,4210146,4210147,4210148,4210149,4210150,4210151,4210152,4210153,4210154,4210155,4210156,4210157,4210158,4210159,4210160,4210161,4210162,4210163,4210164,4210165,4210166,4210167,4210168,4210169,4210170,4210171,4210172,4210173,4210174,4210175,4210176,4210177,4210178,4210179,4210180,4210181,4210182,4210183,4210184,4210185,4210186,4210187,4210188,4210189,4210190,4210191,4210192,4210193,4210194,4210195,4210196,4210197,4210198,4210199,4210200,4210201,4210202,4210203,4210204,4210205,4210206,4210207,4210208,4210209,4210210,4210211,4210212,4210213,4210214,4210215,4210216 2017-07-05 05:40:06Z 179925052680 Again, it was at chunk number 1008805 and after a SINGLE server error it's back at 4210125. It does not seem to be retrying chunk 1008805 at all. It does not, in fact, even wait for a second server error. It just starts over at the beginning. So, again, are there additional attempts to retry these reads that are not being recorded in the logs? Or are we still just failing to understand each other about the problem? Additionally, the drive is not unmounting at all--well, not most of the time. It's just restarting the indexing process. So the expected behavior if it was getting multiple errors within a 120 second window is also not obtaining. I can also tell you that I've literally been sitting here and watching the service tracing logs when this happens, and it certainly isn't waiting 120 seconds between getting that error and starting over. It's a matter of seconds. Maybe one or two. I appreciate that Alex is already looking at it, but I also want to make sure that we're clear about this particular problem--and I'm not sure that we are. Again: this is a separate, less tolerant behavior during the reindexing process than the 120 sec threshold timeouts that you are describing. At least as far as I can tell. If there is something I'm missing, though, please let me know. Quote
0 Christopher (Drashna) Posted July 27, 2017 Posted July 27, 2017 I'll have to double check, but the general logic for any sort of API call here (be it enumeration like this, uploading, downloaded, etc) is that when it's failed, it will be retried. That said, you are seeing the "internal error" code, which is a server side HTTP error (specifically HTTP 500, usually). It means something "bad" happened on the server side. Retrying shoudl happen, but may cause issues. Also, for reference, notice the ":26" for in each of the requests? This is the thread number, so you can see that this thread is working on the same stuff (indexing and storing to SQLite) I have flagged the issue for review, including some of that you're seeing. And I've asked a couple of questions about handling/retrying/special handling for this. Hopefully, we're able to get to this issue soon, and fix it quickly. Quote
0 srcrist Posted July 27, 2017 Posted July 27, 2017 OK, great. Keep us posted. And thanks for looking into it with Alex. Quote
0 borez Posted July 29, 2017 Posted July 29, 2017 Sadly, I'm back with more problems. I've updated to the latest beta and I need to reauthorize the drive everytime it starts. Logs show a "Cannot start I/O manager for cloud part xxx (security exception). Security error." problem. When I reauthorize (and if I'm lucky), CD gets back online without re-indexing. If I'm not then it re-indexes everything all over. Any idea? 0:00:30.3: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:00:30.4: Information: 0 : [Main] Cleaning up cloud drives... 0:00:30.5: Information: 0 : [CloudDrives] Valid encryption key specified for cloud part xxx. 0:00:30.6: Warning: 0 : [CloudDrives] Cannot start I/O manager for cloud part xxx (security exception). Security error. 0:00:30.9: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:00:30.9: Warning: 0 : [CloudDrives] Cannot start I/O manager for cloud part xxx (security exception). Security error. 0:00:31.6: Information: 0 : [ChunkIdSQLiteStorage:4] Cleaning up drives... 0:00:31.6: Information: 0 : [Main] Enumerating disks... 0:00:31.6: Information: 0 : [Disks] Updating disks / volumes... 0:00:33.1: Information: 0 : [Main] Starting disk metadata... 0:00:33.1: Information: 0 : [Main] Updating free space... 0:00:33.1: Information: 0 : [Main] Service started. 0:12:44.2: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:12:44.2: Warning: 0 : [CloudDrives] Cannot start I/O manager for cloud part xxx (security exception). Security error. 0:12:46.0: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:12:46.0: Warning: 0 : [CloudDrives] Cannot start I/O manager for cloud part xxxx (security exception). Security error. 0:13:14.4: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:13:18.9: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:13:18.9: Information: 0 : [Disks] Got Pack_Arrive (pack ID: yyy)... 0:13:18.9: Information: 0 : [Disks] Got Disk_Arrive (disk ID: yyy)... 0:13:19.9: Information: 0 : [Disks] Updating disks / volumes... 0:13:20.4: Information: 0 : [CloudDrives] Synchronizing cloud drives... 0:13:20.9: Information: 0 : [Disks] Got Volume_Arrive (volume ID: xxxx, plex ID: 00000000-0000-0000-0000-000000000000, %: 0)... 0:13:20.9: Information: 0 : [Disks] Got drive letter assign (volume ID: xxx)... 0:13:22.5: Information: 0 : [Disks] Updating disks / volumes... 0:13:24.9: Information: 0 : [Disks] Got Disk_Modify (Disk ID: xxx 0:13:24.9: Information: 0 : [Disks] Got Disk_Modify (Disk ID: xxx and more... Quote
0 Christopher (Drashna) Posted August 1, 2017 Posted August 1, 2017 Try logging out and logging back into your accounts, and see if that helps. If not, then run this: http://wiki.covecube.com/StableBit_Troubleshooter Quote
arkx82
I did reboot PC.
"Drive mount Error"
what can I do..
9 answers to this question
