lowflow 0 Posted December 22, 2016 Share Posted December 22, 2016 Can someone help me out and give me the best settings for google drive. I have a 75/75 connection. Quote Link to post Share on other sites
0 Domen 1 Posted December 23, 2016 Share Posted December 23, 2016 I have a 300/40 Mbps connection. For my main CloudDrive, that I store my active projects (Video, Photo) on, I have the following settings. These may not be optimal, because Google Drive limits the number of concurrent connections to 20, but this configuration can max out even a 1Gbps uplink.The prefetch trigger is something that you really need to set yourself. I work with large files and benefit greatly from prefetching, but your data might not. Quote Link to post Share on other sites
0 tanjer45 3 Posted December 23, 2016 Share Posted December 23, 2016 I have a 300/40 Mbps connection. For my main CloudDrive, that I store my active projects (Video, Photo) on, I have the following settings. These may not be optimal, because Google Drive limits the number of concurrent connections to 20, but this configuration can max out even a 1Gbps uplink. The prefetch trigger is something that you really need to set yourself. I work with large files and benefit greatly from prefetching, but your data might not. What is your download speed? Mine max out on ~30mbp/s and i cant have more than 2-3 streams on plex at any given moment. The upload was great, but i am disappointed about the download. I have a 700mbp/s download link so the "muscles" are there. Quote Link to post Share on other sites
0 Christopher (Drashna) 631 Posted December 30, 2016 Share Posted December 30, 2016 If you're seeing performance issues with Google Drive on the 1.0.0.777 or 1.0.0.778, then please upgrade to this version: http://dl.covecube.com/CloudDriveWindows/beta/download/StableBit.CloudDrive_1.0.0.784_x64_BETA.exe There is a performance issue with larger drives, and this will fix the issue. Quote Link to post Share on other sites
lowflow 0
