I'm running DrivePool in Windows 11. I have 14 HDDs, and DrivePool has combined them into a single "drive".
Most of the drives are 75% full, but one is over 90% full. (The combined drive is about 75% full.) Every time DrivePool starts balancing the drive, something interrupts it -- usually Windows 11 stops recognizing one of the HDDs -- and the balancing starts again. The bottom line is that DrivePool isn't moving the data it needs to in order to balance the drives.
Is there any way I can move files from the 90% drive to one of the other drives to balance the files manually? If I move files, will DrivePool be able to find them?
If I can't do that, any suggestions about how to force DrivePool to start moving files from the 90% drive to some of the other drives?
dfleiss
Thank you.
7 answers to this question
