drmcsmoothie Posted August 16, 2013 Posted August 16, 2013 Possible to have a setting to switch between Celsius and Fahrenheit? Quote
0 Doug Posted August 16, 2013 Posted August 16, 2013 From the change log for Scanner (see Scanner Settings -> Heat). 2.4.0.2922 / 2.4.0.2923-----------------------* Disk temperature will now be reported in either Celsius or Fahrenheit (see Scanner Settings -> Heat). It defaults to your regional settings in Windows. http://stablebit.com/Scanner/ChangeLog?Platform=whs2 Quote
0 Christopher (Drashna) Posted August 16, 2013 Posted August 16, 2013 Yes, this was added a while ago. Make sure you've updated StableBit Scanner. And the setting, open the UI (either the dashboard on the WHS version, or the stand alone app). The "Start/Stop/Automatic" toolbar at the top, click the arrow next to the "Scanner Settings" box, and select "All Settings". Then open the "Heat" tab. You'll be able to choose which setting from there. Quote
0 drmcsmoothie Posted August 16, 2013 Author Posted August 16, 2013 Pretty sure I posted in the right area. I understand this for StableBit Scanner. I am talking about StableBit DrivePool. If you hover the mouse cursor over the one of the drives. There is a quick view and it has the temp. I see no setting for switching between Celsius and Fahrenheit in DrivePool. Quote
0 Doug Posted August 16, 2013 Posted August 16, 2013 What version are you using? This is what I get hovering over a disk in v1.3.3.7563. Quote
0 Christopher (Drashna) Posted August 16, 2013 Posted August 16, 2013 Ah, okay. And yeah, it's grabbing the info from scanner, but not it's settings. Quote
0 gtechwi Posted September 9, 2013 Posted September 9, 2013 +1 for DrivePool 2.x to report temperature in F Quote
0 Alex Posted September 10, 2013 Posted September 10, 2013 You're right, the temperature in DrivePool was not respecting the C/F setting in the Scanner. This has already been fixed in the latest builds of DrivePool 2.X but it requires a new build of the Scanner which have not been built yet. The next build of the Scanner will have the necessary code to make this work. So in short, this will resolve itself with some time and a newer build. Quote
drmcsmoothie
9 answers to this question
