Sacred Posted September 24, 2023 Posted September 24, 2023 Hello; I'm trying to modify the Settings.json and I'm missing the entry for CoveFs_WaitForVolumesOnMount which is mentioned in the wiki: https://wiki.covecube.com/StableBit_DrivePool_2.x_Advanced_Settings Is this normal, if I add this entry manually it gets deleted after every restart of the StableBit Drive Pool Service? Quote
0 Shane Posted September 25, 2023 Posted September 25, 2023 Hi Sacred, the entry should be CoveFs_WaitForVolumesOnMountMs and that entry should already be present in the Settings.json file. You might also want to try stopping the service before editing the file, only then restarting the service afterwards. Quote
0 Sacred Posted September 25, 2023 Author Posted September 25, 2023 Okay, in the wiki it sounded to me that there would be two entries, is this a misunderstanding? CoveFs_WaitForVolumesOnMount (Default: "True") - Some volumes arrive late in the boot process so DrivePool will wait for all the volumes to arrive before allowing the pool drive to mount. The delay is adaptive, so it will be different for each system. Turning this off might shorten boot times, but is not recommended because it could expose a partially populated pool drive to system services that start right after booting. CoveFs_WaitForVolumesOnMountMs (Default: "10000") - How long to wait for all the volumes to arrive in MS. Quote
0 Shane Posted September 26, 2023 Posted September 26, 2023 Hmm. I tried adding the entry and experienced the same result as you. I've looked at the change log for DrivePool and I suspect that CoveFs_WaitForVolumesOnMount was actually replaced with CoveFs_WaitForVolumesOnMountMs when the latter was added as of version 2.2.0.891 - so if your version is that or later then I believe you should use the latter entry (and setting a value of 0 for it would be equivalent to setting a value of false for the former entry). @Christopher (Drashna) does the wiki need to be amended to indicate that the first entry has been deprecated in favor of the second entry, or is something else going on? Quote
0 Christopher (Drashna) Posted September 26, 2023 Posted September 26, 2023 Make sure that you're changing the "override" value, and not the default. The default may get overwritten, but the override value shouldn't. Quote
Sacred
Hello;
