frostiex Posted September 24, 2023 Posted September 24, 2023 I don't have drivepool yet, but I wonder if it is possible to have only one pool, as the C drive and boot drive? I am guessing not because drive pool is done on the OS level? Quote
1 Shane Posted September 24, 2023 Posted September 24, 2023 It's not possible; the operating system has to be loaded before DrivePool can start. You could mount a pool as a folder on the boot drive (e.g. have it show up as "c:\pool" instead of "d:\") but not as the boot drive itself. Quote
0 VapechiK Posted September 24, 2023 Posted September 24, 2023 i am not the sharpest knife in the drawer but i cannot think of any logical reason to include the system boot/OS drive as a pooled drive in any DrivePool setup. the potential for shooting oneself in the foot is immense. as @Shane said, you can use a folder on the OS drive (or any drive) to mount your drives within but that is another thing entirely. and you are guessing correctly as DrivePool is not loaded until after/as Windows boots. if you have, say, only one 2TB (generally 1.8TB usable) ssd you could partition 300GB for the Windows OS (C:\) and partition the remaining 1.5TB as data storage (D:\) and add/make a pool from D then add more drives when acquired. spend time here: https://stablebit.com/Support/DrivePool/2.X/Manual and reading through the forums so you know what you're getting into cheers Quote
frostiex
