Scanner default settings
Per
Hello, I have seemed to messed up the SSD scanning settings. I wonder what are the default settings for:
1.  Check readable/unchecked sectors:  ?? days
2. Re-check unreadable sectors :   ?? days
3. Check filesystem:    ?? days
I'd like to restore default values. And could someone explain the logic behind those (default) settings?
regards
Per
YOu can use the "Quick settings" to reset these values.
And the different profiles do have slightly different profiles.
As for the settings, and what they do, there is some basic information about that here:
https://stablebit.com/Support/Scanner/2.X/Manual?Section=Scanner
