Hi all, I've been using drivepool in conjunction with snapraid for a few years without issue, but have ran into a weird issue when adding two empty drives to my pool.
For context, my current setup is an ITX PC (4x8TB drives) + Mediasonic probox (8+10+10tb) + mediasonic probox (3x14tb). Proboxes are connected via USB 3.0 and have had no issues maxing out their bandwidth when syncing with snapraid or balancing in the past. I consistently check SMART data and have confirmed many times that all these drives are able to hit their rated speeds via file transfers, both in and out of the pool. S2D2 is SMR, but it hasn't come into play during this issue yet and it's speeds aren't that far behind the other drives anyways. All other drives are CMR.
I added 2x14TB drives to the pool, one in each of the proboxes. After re-measuring the pool, it calculated new balance targets and started balancing. It was taking an incredibly long time, only 5% after 24 hours, so I checked drive performance in Task Manager and one of the new drives (S2D1) was only doing 10-15MB/s while the other wasn't filling at all. I also found it odd that it was only balancing files from a single drive instead of multiple, but that could just be normal behaviour that I'm not familiar with. Note: I've disabled any scheduled snapraid tasks in the meantime to not interfere with the balancing.
Things that I've tried:
increasing priority of the balancing job. No effect on transfer speed. Tried stopping the balance and restarting with that enabled; no change.
Looking for errant processes that are using disk resources - None I could find.
Trying different balancing settings/plugins - same issue between all.
killing drivepool service and restarting it. It started filling the other new drive (S3D1) but still at 10MB/s.
Screenshots below showing the drive's performance in task manager and of the pool.
sophvvvv
Any ideas or suggestions are welcome! TIA!
7 answers to this question
