I'm having problems with maintaining stability on my computer after adding a SAS controller connected to an HP MSA70 maxed out with 24 drives. This brings the total of drives in my computer to 81 Only the system drive and 24 SAS drives are other than USB. After it runs for about 30 minutes it gives the BSOD with WDF_Violation.
The SAS controller I'm using seems to break it. But if all of the USB drives are disconnected the SAS works perfectly. It's just that not everything works perfectly together.
Am I putting too much strain on it? What would others recommend?
TerryMundy 1
System is:
HP Z440 latest BIOS
Windows 10 Professional 64 bit 2004 Sept 2020
32GB of RAM
Xeon E5-2630 v3 not overclocked
Any help is appreciated!
Terry
