AMCross 11 Posted January 14 Share Posted January 14 hi there been working fine for years and today after a 8 month rest i powered up my home server with both product scanner and drivepool requiring an update carried out the update but licence details have gone copied and pasted my activation and get an error licence not found going onto stablebit cloud machine is showing and all seems ok but drivepool is showing no pool however my machine is showing a pool any ideas Link to post Share on other sites
gtaus 19 Posted January 14 Share Posted January 14 +1 Have a similar problem with using the DrivePool GUI on one of my remote computers. Got the error message "Licence not Found/valid" despite DrivePool is up and running fine on the server. I have narrowed down my issue to having different DrivePool versions on the server and that remote computer, i.e. the server is running Version 2.2.4.1162 whereas the remote computer had the latest update. So, I tried to update my server with the latest version of DrivePool, but it does not auto update and when I click on force update check, it just says it will notify me but does not. So I'll have to figure out how to update manually. Now I wonder if my license will work if I update DrivePool on my server. My license number for DrivePool GUI did not work on the update version on my remote computer. Currently I am using Remote Desktop to control DrivePool on my server from a remote computer, but the remote DrivePool GUI would be my preferred method. AMCross 1 Link to post Share on other sites
AMCross 11 Posted January 14 Author Share Posted January 14 i was also getting an update was due but couldnt update as failed went onto cloud and showed one of the programs was out of date so downloaded latest beta from website Link to post Share on other sites
Christopher (Drashna) 618 Posted January 15 Share Posted January 15 Well,I think I may know what is causing this. If this is a brand new release stable, we recently found a bug with the licensing that would make it appear to be working fine, while in fact it was on an expired trial license. Upating could produce this sort of issue. Reactivating should fix the issue. If this isn't the caes, or if you can't activate your license, head to https://stablebit.com/contact and we'll get you sorted out. Link to post Share on other sites
AMCross 11 Posted January 15 Author Share Posted January 15 thanks for the reply ive opened a support ticket Link to post Share on other sites
