I formatted my machine and reinstalled windows. After reinstalling everything the pool drive showed up as it should and my pool was where it was before. Problem is I have a 500gb SSD that's perfectly healthy from another machine but i cant add it to the pool. If its unformatted with no partition, it shows up in the list. When I add it I get this error. If i try to create a simple partition and format it it works fine in windows, but Stablebit doesn't see it in the list to add! Any help is appreciated!
Titan Alpha 0
