blaineeasy 0 Posted September 24, 2020 Share Posted September 24, 2020 I have DrivePool installed on Win Server 2016 and have several drives pooled to make a single DP drive. In Disk Management, can I enable Shadow Copies on the pooled drive? Or can I only enable it on the drives that make up the pooled drive? I was looking through the forums and finding that DP does not support Shadow Copies and don't want to screw something up by enabling it. Thank you! Quote Link to post Share on other sites
0 Shane 45 Posted September 26, 2020 Share Posted September 26, 2020 Only on the drives that make up the pool. Quote Link to post Share on other sites
0 blaineeasy 0 Posted September 30, 2020 Author Share Posted September 30, 2020 On 9/26/2020 at 12:09 AM, Shane said: Only on the drives that make up the pool. thanks! Quote Link to post Share on other sites
blaineeasy 0
Thank you!
