DrivePool Remote Control
HTWingNut
 Share
I have been using DrivePool for some time now with a registered copy on my home server.
I installed a copy of DrivePool (and Scanner) on my laptop and desktop PC. Trial version only. It was successfully able to connect to my server for remote access no problem.
Same with Scanner, was able to connect to my home server. I recently purchased a license for Scanner for both my laptop and desktop. Since I upgraded Scanner, I can no longer connect either Scanner or DrivePool to my server.
Also, just for clarification, I understand that I don't need a DrivePool license if all I want to do on my other PC's is remote control DrivePool app on my server, correct?
I had a similar problem on my computers. Everything was working fine with the remote control for months on my computers. I upgraded DrivePool on my main server (with license), and then none of the remote controls (without license) worked on my other computers. In my case, I was able to update DrivePool on my remote computers and once all computers had the same DrivePool version numbers, they worked again. If you have additional plug-ins in use, you need to also install them on your remote computer(s).
 Share
