Hello,
I'm having trouble removing a CloudDrive disk from DrivePool, which I believe is largely due to a ~215GB file that DrivePool keeps failing to copy to a local disk. I figure I may have more success with Robocopy, and was wondering if its possible to Robocopy the file directly from the CloudDrive PoolPart folder to the PoolPart folder on one of the local disks? If not, I'll Robocopy it to a non-pooled disk.
Thanks
Stuart
It is possible but I would advise to copy it to the intended target disk but outside of the PoolPart.* folder. Then, if/once succesfull, delete from Pool and then simply move on target disk from location to intended location within PoolPart.* folder.
