omniaton
Is there a way to upload only at night or after a larger upload threshold?
CloudDrive is pretty awful at torrenting when there is background IO. The speed often fluctuates between 0 and my regular download speed every few seconds. This doesn't happen when I download directly onto a hard drive. I'm thinking this would be solved if I could download onto my cache drive first directly and not upload until later when the entire file is downloaded. I could achieve this with scripts but I was wondering if there was some method baked into CloudDrive. I was thinking a larger upload threshold value or nightly upload would work but I'm not too sure. Thanks in advance!
There is a performance setting to adjust your upload threshold, but turning off background IO in the performance settings will help this too. The default IO priority will prioritize writes over reads.
