riahc3 3 Posted February 19, 2019 Share Posted February 19, 2019 Hello I was going to buy Stablebit Scanner but during the trial period I just noticed something... It is not giving me any S.M.A.R.T data and says it is not accessible. I installed smartctl and right out of the bat, it can access the S.M.A.R.T. data, show me values, etc.... The ability to see S.M.A.R.T data and even notify me is a BIG reason I got the bundle the first time around. Now, if it doesnt work, why should I? Im using the SAME drives that worked in a similar setup so...Its not a drive issue. Quote Link to post Share on other sites
0 Umfriend 105 Posted February 20, 2019 Share Posted February 20, 2019 What kind of controller are they attached to? Quote Link to post Share on other sites
0 Christopher (Drashna) 619 Posted February 20, 2019 Share Posted February 20, 2019 @Umfriend's comment is important. Some controllers won't show the SMART data out of box. This is because it may need methods that have been known to cause issues, and are in our blacklist. You can enable this by enabling the "unsafe" option in the advanced settings. http://wiki.covecube.com/StableBit_Scanner_Advanced_Settings Quote Link to post Share on other sites
0 riahc3 3 Posted February 23, 2019 Author Share Posted February 23, 2019 On 2/20/2019 at 7:57 PM, Christopher (Drashna) said: @Umfriend's comment is important. Some controllers won't show the SMART data out of box. This is because it may need methods that have been known to cause issues, and are in our blacklist. You can enable this by enabling the "unsafe" option in the advanced settings. http://wiki.covecube.com/StableBit_Scanner_Advanced_Settings Enabling unsafe mode did the trick and now shows S.M.A.R.T. data. Quote Link to post Share on other sites
0 Christopher (Drashna) 619 Posted February 27, 2019 Share Posted February 27, 2019 Awesome, glad to hear it! Do you know what controller this is? (you can use the sort option in StableBit Scanner to sort "By Controller" to see which it is) Quote Link to post Share on other sites
riahc3 3
Hello
