alwi27 Posted August 25, 2018 Share Posted August 25, 2018 Hi Does Stablebit DrivePool have muilti read when copying files from a disk that is duplipcated? Br Alexander Quote Link to comment Share on other sites More sharing options...
0 Jaga Posted August 25, 2018 Share Posted August 25, 2018 Yes it does Alexander. You need to make sure that "Read Striping" is enabled in Drivepool. Click on the up-arrow next to "Manage Pool", move your mouse over "Performance" so it pops out, then make sure there's a check mark next to Read Striping. If there isn't, left-click it to enable it on the pool. Note that it only works for pools with duplication on, or for folders/files that are specifically duplicated. The pool needs to have >1 physical drive in it, and the read performance with multiple drives also depends on their speeds compared to each other. Example: if you have a pool with 1 spinner drive and 1 SSD drive and duplication is turned on, most of the time Drivepool will choose to read from the SSD first since it knows the performance is higher there. Drivepool's read striping can also take advantage of >2 drives with Read Striping. The more drives you have the higher a chance of getting higher throughput. It works best on larger duplicated files where reads can be sustained. Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted August 30, 2018 Share Posted August 30, 2018 Yup. But what it does exactly depends on a lot. https://stablebit.com/Support/DrivePool/2.X/Manual?Section=Performance Options#Read Striping Quote Link to comment Share on other sites More sharing options...
alwi27
Hi
Br
Alexander
