JohnKimble 4 Posted June 23, 2017 Share Posted June 23, 2017 To see what files Clouddrive is currently downloading or what process is trying to read from the CloudDrive? Would be handy to see because something is reading from the drive causing constant prefetching. Antoineki 1 Quote Link to post Share on other sites
0 srcrist 65 Posted June 23, 2017 Share Posted June 23, 2017 CloudDrive is a block based solution, so the software doesn't really know what files it's accessing. You should be able to use any windows tool, like resource monitor, to see what is accessing the drive and what files are being accessed though. Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted June 26, 2017 Share Posted June 26, 2017 srcrist is correct, you won't be able to see what files are being downloaded, because the software doesn't deal with 'files". However, the technical details window will show you what chunks are being uploaded and downloaded. http://stablebit.com/Support/CloudDrive/Manual?Section=Technical%20Details As for processes that are reading from the drive, run "resmon" and open the "disk" tab. Quote Link to post Share on other sites
0 Edrock200 6 Posted July 1, 2017 Share Posted July 1, 2017 Make sure you turn off drive indexing and exclude your drive from scheduled antivirus scans. Quote Link to post Share on other sites
JohnKimble 4
