HELP! Accidentally deleted large number of .iso files from DP -
I accidentally deleted a number of .iso files from my drive pool.
Can anyone recommend a program / procedure that will help recover from pool part?
Appreciate any responses...
do not let the pool balance - in fact disable the service
do you not have the recycle bin enabled?
if not then - look for a undelete program via google that works with ntfs
point it at your pool part folders for each drive and see if you can recover etc
