I migrated a friend to windows 10 a few weeks ago and he had DP installed on WHS2011. I reinstalled DP and the pool came back up. Now the problem...At first 3 drives kept going missing and wouldnt come back up till i restarted the machine. This actually killed a 2TB drive and caused bad sectors on a brand new 5tb we had just put in.I ended up figuring out that the problem was the PCIE sata card. So i removed it and replaced it with a mediasonic probox.
Now i thought all the problems were fixed but now every time i go into the balancer options and into placement, the GUI stops responding, The pool becomes inaccessible, the DP service hangs on stopping if i try to stop it. and if i try to restart the machine windows hangs on the Restarting message( stayed there for 2hrs) and i am force to use the power button to restart. When i restart the PC stays on the windows logo and it spins. I am letting it run a bit to see if it will pass but i have also rebooted a few times until i got it to start. I think it is one of the drives causing the issue but i was thinking that maybe the DP logs could shed some light. Scanner seems to not see anything out of the ordinary.
saitoh183
So how should i proceed to get the logs?
6 answers to this question
