So I woke up this morning to some alerts from Scanner that 2 of my drives had filesystem issues (both drives are in a pool).
Running the link to fix the drive within the Scanner fixed one drive right away but my 8TB drive failed and asked me to run chkdsk manually. I assigned the drive a letter and chkdsk reported the following:
Stage 3: Examining security descriptors ...
Security descriptor verification completed.
11604 data files processed.
The Volume Bitmap is incorrect.
Windows has checked the file system and found problems.
Running it with the /scan switch found no issues but running it without it did. Here is the full output of both commands run back to back:
PS C:\Users\Administrator> chkdsk.exe g: /scan
The type of the file system is NTFS.
Stage 1: Examining basic file system structure ...
208384 file records processed.
File verification completed.
6400 large file records processed.
0 bad file records processed.
Stage 2: Examining file name linkage ...
231592 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered to lost and found.
Windows has scanned the file system and found no problems.
No further action is required.
7630883 MB total disk space.
5479076 MB in 188976 files.
77960 KB in 11606 indexes.
0 KB in bad sectors.
513531 KB in use by the system.
65536 KB occupied by the log file.
2151229 MB available on disk.
4096 bytes in each allocation unit.
1953506303 total allocation units on disk.
550714792 allocation units available on disk.
WARNING! /F parameter not specified.
Running CHKDSK in read-only mode.
Please run chkdsk /scan to find the problems and queue them for repair.
Is this an issue and if so, can it be safely fixed or am I looking at a drive replacement?
tomsliwowski
8 answers to this question
