ross.dargan Posted September 2, 2016 Posted September 2, 2016 I've attached a screenshot to show what I mean. For some reason even after weeks I can't get drivepool to use this drive. I have Volume Equalizer after StablebitScanner so I think it should be trying to put stuff on there. Quote
0 gyrene2083 Posted September 2, 2016 Posted September 2, 2016 I'm still new to using Drivepool, so this may not apply to you, but did you check the prevent drive overfill? It defaults to 90 percent, which on a 2TB drive is 100GB, surely enough for a blu-ray, so it balances out if there are any drives above 90 percent it will take them off of that drive and put them on a drive that is not near that limit. I hope that helps and if I am wrong please let me know. -Semper Fi gyrene2083 Quote
0 ross.dargan Posted September 2, 2016 Author Posted September 2, 2016 I would have thought that the volume equalizer balancer should cause stuff to be put on here? Maybe I don't understand it properly! Quote
0 Christopher (Drashna) Posted September 2, 2016 Posted September 2, 2016 Volume Equalizer is for multiple partitions on the same physical disk. Also, unless you're actively adding data, it won't rebalance the data to use the drive. If you want to force the pool to be equally used, download, install and enable the "Drive Space Equalizer" balancer plugin. https://stablebit.com/DrivePool/Plugins This balancer plugin will rebalance the pool so that all the disks are using roughly the same amount of space. Quote
ross.dargan
