1) I get this message sometimes. Why is it reporting overheating at 28 celsius (82F) when the overheating threshold for WD Red 3TB is set to 65 Celsius?
StableBit ScannerHeat Warning on "SERVER".One or more disks are overheating:
ATA WDC WD30EFRX-68E SCSI Disk Device - 28˚C (Maximum: 0˚C)
Model: WDC WD30EFRX-68EUZN0
Serial number: WD-WCC4NH73X1NR
You are receiving this message because you have set up email notifications to be sent to this address from the StableBit Scanner.
2) Scanner has been getting a lot of bad sectors on my WD Reds, 3 replaced in the past 6 months. Sometimes they are actually bad and I can verify with the other tools. This time I just ran a short and extended test with WD Lifeguard which did not detect any bad sectors. Which software is true, bad sectors or no bad sectors?
quietas
