I recently upgraded my home server and moved away from Windows 10 to Windows Server 2022. To my dismay, my personal Backblaze account does not work with Windows Server. After further research, it seems the solution is to upgrade to Backblaze B2. But I quickly realized that Backblaze B2 with Cloudberry also does not work to backup DrivePool drives because it is considered a "Volume Shadow Copy". I think I have a solution that might work, using drivepool with clouddrive and Backblaze, but I wanted to confirm with the Stablebit user community. My current drivepool configuration consists of four 3TB hard drives that are duplicated four times. My thought was to create a fifth 3TB CloudDrive that I would pool with my existing drives and change the duplication to 5 times. This way I would have 4 physical 3tb harddrives and one virtual 3tb harddrive. The virtual drive should automatically sync with backblaze B2. In case of a failure, I could restore the clouddrive in a new machine.
My second question is whether the 3TB clouddrive actually takes up 3tb of space in backblaze. If I only have 1.5tb of files, will I be charged for the 1.5tb of usage or the full 3tb drive.
Let me know if this though process is flawed or if it should work. Thanks for your help!
digimon
