Sharing with crossover ethernet cable? Or other hard connection?
baccarat
What is the best way to share a pooled drive with another machine using a cable connection? Both are Win 7. I was thinking USB 3.0 transfer cable but there only seem to be 2.0 ones and apparently not very good. Anybody sharing with a crossover ethernet cable directly between 2 PCs without going through some network or hub?
For the computers, any eithernet cable should work, I believe. They should autodetect.  However, if you do that, you'll have to make sure that you're manually setting the IP addresses for both machines (or you grab the "auto-assigned" one).
Though, you could connect both to a router (even if it's not plugged into a cable modem, as that would simplify everything.
