Benplace23 Posted June 26 Share Posted June 26 As the title says, is there any way to run a scan and only recheck the bad blocks? Quote Link to comment Share on other sites More sharing options...
0 VapechiK Posted June 26 Share Posted June 26 hi. click the + sign on the left of the drive, then the green circular arrow and if bad blocks exist, the red circular arrow should be selectable from the dropdown. click it and then click the blue > button and i 'assume' Scanner will prioritize those blocks and scan only them if the rest of the drive is healthy (the sector map is neon green). a few months ago i had a weird power issue and i think the MFT was somehow corrupted on a couple of my BU drives, so the only blocks marked bad were the very first ones on the bottom right. i did the above and Scanner ran a chkdsk pass and cleaned them up very quickly. if you have actual damaged sectors deep in the drive YMMV. cheers Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted June 27 Share Posted June 27 Yup. If you mark the bad blocks as unchecked, it will attempt to scan those blocks at the next available time (typically immediately). If the rest of the disk is marked as healthy, it will only scan these blocks (as it only scans sections of the disk that are not checked or haven't been checked in the normal scan window (30 days). VapechiK 1 Quote Link to comment Share on other sites More sharing options...
Benplace23
