Junction points & symbolic links keep being recreated. How to clean reparse points / folder metadata?
Quote
Windows 11 Pro x64 22H2 2261.1265
Drivepool 2.3.2.1493
I've encountered/solved this problem once before, but I don't remember what ended up working.
I used to have a junction point E:\Downloads, which pointed to C:\Downloads.
I deleted this junction point, and created a new one E:\Downloads, which now points to D:\Downloads.
Every time I reboot my computer, the junction point gets replaced with one that points to C:\Downloads.
If I create an empty folder E:\Downloads and reboot my computer, it also gets replaced with a junction point, pointing to C:\Downloads.
If I delete E:\Downloads and reboot my computer, I can create a new folder E:\Downloads, which immediately gets replaced with a junction point.
It's as if there's some 'old' drivepool metadata that doesn't get cleared out when I delete the folder/junction point.
E:\ is my Drivepool. C:\ and D:\ are physical disks, which aren't part of the pool.
Is there any way to tell Drivepool to do housekeeping, and blow out this old metadata for folders/junction points which no longer exist?
Well that wasn't terribly exciting. I expected DrivePool to complain or explode or something.
The .covefs folders on a few of my drives had wonky permissions from being migrated between computers, so I'll bet that was the issue.
It appears to have fixed my problem.
Thank you!
