Internal SSD to Drive Pool full speed, SSD over network to DrivePool won't even saturate gigabit
basically an optimization question. I tested all 4 of the disks in my pool with Scanner, they all did about 250-350MB/s, so my USB controllers are good. I enable jumboframes on both the host and clients. Internal SSD has fantastic performance 600MB/s to the buffers and sustains 250-300MB/s after that. I have network i/o boost on, but I cannot get more than about 600Mb/s over the gigabit network, and I'm expecting to get 900+ with overhead. Any tips at things I should look at?
19 hours ago, Christopher (Drashna) said:
Have you messed with the autotuning?  if not, that is the usual culprit.  Setting it to highlyrestricted can help, a lot.
Try running this on any system involved:
netsh interface tcp set global autotuninglevel=highlyrestricted
And reboot the system.
Ok did that, CMD output "OK" so I assume that did it. still capping out at 730ish mbps. Do I need to run that on the client machine as well?
On 6/17/2022 at 12:31 PM, Christopher (Drashna) said:
Yeah, you want to run it on both systems, and you want to reboot after running it to ensure that it takes effect.
unfortunately, didn't make a difference, still limited to about 700mbps
