I have 2 hard drives for storage and have them duplicating the files on them. 1 of them has 22 bas sectors while the other drive is healthy. I saw that the drivepool has a scanner plugin that when detected it will evacuate the files from the bad hard drvie to others. My question is i have only 2 hard drives so it cant really evacuate it to another hard drive so its continues on the bad hard drive however does drivepool neglect those bad sectors when reading/writing new info or stops using that hard drive? I was hoping someone could clear how this function works, i feel that the description of it is a bit vague
Also what would you recommend to do on this hard drive? can this be fixed some how? they are 2 samsung hd204ui and samsung doesnt support them no more since i guess seagate took over their hard drives?
gambit19
