Reinstall Issue after replacing system C disc whs 2011
AMCross
 Share
had a disc failure so did a reinstall and cannot get shares to repolulate using whs troubleshooter
steps followed
1.  powered down server
2   replaced c drive
3. disconnected all data drives
4. did reinstall as backup image wouldn't work
5. installed all updates
6. installed driverpool and scanner
7. changed pool to Z
8. changed blu ray player to W
9. reconnected all data drives one at a time to make sure drive 1 was e drive 2 was f  etc
10. drivepool show 8 discs in pool
but when I run wss troubleshooter to redo shares I get an error  fix was not successful access is denied
any help please
13 answers to this question
hi there
drivepool is showing the 8 discs
I had reset permissions forgot to tell you about that step :-(
still the same running as admin
shows something quicly then go straight to access denied
using remote desktop connection
i really wonder if i should dump this whs2011 and get essential 2012
spend days trying to sort it then presto it works :-)
all drives checked ok as well
now cannot get the connector software to work
thanks for the help
.... Ah, technology.... a fickle mistress... :P
Well, glad it suddenly decided it wanted to work... but still looks like you're having other issues.  Maybe you should consider doing a fresh install of WHS2011. It sounds like the system has issues (or maybe run "sfc /scan").
But what's happening specifically with the connector software? And have you tried disabling IPv6 yet?
As for the pending reboot, that occasionally happens. Assuming that you've rebooted a couple of times already to try and clear this, then you need to do this:
  1. Open up Registry Editor (run "regedit)
  2. Find the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager"
  3. Rename the "PendingFileRenameOperations" value to "PendingFileRenameOperations2"
After that, try rebooting.
As for the connector issue, I'm a WHS veteran, and I've seen all sorts of weird issues. Disabling IPv6 will sometimes fix this issue.
thanks very much drashna for your effort in helping me
disabled both server and pc from using ipv6
still the same
log attached
[07/09/2013 12:40:54 1420] ***-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-***
[07/09/2013 12:40:54  d68] Service: Client Update service started.
[07/09/2013 12:40:54  d68] ClientUpdate: DoStart() entry
[07/09/2013 12:40:54  d68] ClientUpdate: started main thread
[07/09/2013 12:40:54  940] ClientUpdate: Main starting
[07/09/2013 12:40:54  d68] ClientUpdate: DoStart() exit
[07/09/2013 12:40:54  940] Events: Created PRS event
[07/09/2013 12:40:54  940] Events: Unable to adjust PRS event security, GLE=0x0
[07/09/2013 12:40:54  940] [DelayStartup]
[07/09/2013 12:40:54  940] [startup] Server INTELHDSERVER
[07/09/2013 12:40:54  940] [startup] Client LCID 1033
[07/09/2013 12:40:54  940] [startup] Folder C:\ProgramData\Microsoft\Windows Server\Data\Update\
[07/09/2013 12:40:54  940] [Cleanup]
[07/09/2013 12:40:54  940] [idle]
[07/09/2013 12:42:54  940] [idle]
[07/09/2013 12:42:54  940] [CheckVersion]
[07/09/2013 12:42:54  940] [CheckVersion] Source: connect/default.aspx?get=VersionInfo.xml&LanguageId=1033&64bit=0
[07/09/2013 12:42:54  940] [CheckVersion] Target: C:\ProgramData\Microsoft\Windows Server\Data\Update\VersionInfo_1.xml
[07/09/2013 12:42:54  940] [WaitForVersionDownload] Async_Pending 0
[07/09/2013 12:42:54  4b8] Download: started
[07/09/2013 12:42:54  4b8] Download: result: Async_Succeeded
[07/09/2013 12:42:54  940] Dispatch: SOURCE_DOWNLOAD
[07/09/2013 12:42:54  940] [WaitForVersionDownload] Async_Succeeded 1028
[07/09/2013 12:42:54  940] [CompareVersions]
[07/09/2013 12:42:54  940] [CompareVersions] Client info:
[07/09/2013 12:42:54  940] [CompareVersions]     Client = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     Connection = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     LCID = 1033
[07/09/2013 12:42:54  940] [CompareVersions] Server info:
[07/09/2013 12:42:54  940] [CompareVersions]     ClientRequired_MacOS = 1.0.1069.0
[07/09/2013 12:42:54  940] [CompareVersions]     ClientRequired_Win32 = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     ClientRequired_Win64 = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     Client_MacOS = 1.0.1069.0
[07/09/2013 12:42:54  940] [CompareVersions]     Client_Win32 = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     Client_Win64 = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions]     Server = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] versionServer   = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] versionRequired = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] versionOffered  = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] versionClient   = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] connectServer   = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] connectClient   = 6.1.8800.16400
[07/09/2013 12:42:54  940] [CompareVersions] connector version is OK
[07/09/2013 12:42:54  940] [Cleanup]
[07/09/2013 12:43:46 1420] Service: Client Update service stopping.
[07/09/2013 12:43:46 1420] ClientUpdate: DoStop() entry
[07/09/2013 12:43:46  940] Dispatch: SOURCE_MAIN
[07/09/2013 12:43:46  940] [idle]
[07/09/2013 12:43:46  940] ClientUpdate: Main stopping
[07/09/2013 12:43:46 1420] ClientUpdate: Main thread ended normally
[07/09/2013 12:43:46 1420] ClientUpdate: DoStop() exit
[07/09/2013 12:43:46 1420] Service: Client Update service stopped.
[07/09/2013 12:43:46 1420] ***-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-***
[07/09/2013 12:49:38 153c] ***-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-***
[07/09/2013 12:49:38  1f0] Service: Client Update service started.
[07/09/2013 12:49:38  1f0] ClientUpdate: DoStart() entry
[07/09/2013 12:49:38  1f0] ClientUpdate: started main thread
[07/09/2013 12:49:38 1710] ClientUpdate: Main starting
[07/09/2013 12:49:38  1f0] ClientUpdate: DoStart() exit
[07/09/2013 12:49:38 1710] Events: Created PRS event
[07/09/2013 12:49:38 1710] Events: Unable to adjust PRS event security, GLE=0x0
[07/09/2013 12:49:38 1710] [DelayStartup]
[07/09/2013 12:49:38 1710] [startup] Server INTELHDSERVER
[07/09/2013 12:49:38 1710] [startup] Client LCID 1033
[07/09/2013 12:49:38 1710] [startup] Folder C:\ProgramData\Microsoft\Windows Server\Data\Update\
[07/09/2013 12:49:38 1710] [Cleanup]
[07/09/2013 12:49:38 1710] [idle]
[07/09/2013 12:51:38 1710] [idle]
[07/09/2013 12:51:38 1710] [CheckVersion]
[07/09/2013 12:51:38 1710] [CheckVersion] Source: connect/default.aspx?get=VersionInfo.xml&LanguageId=1033&64bit=0
[07/09/2013 12:51:38 1710] [CheckVersion] Target: C:\ProgramData\Microsoft\Windows Server\Data\Update\VersionInfo_1.xml
[07/09/2013 12:51:38 1710] [WaitForVersionDownload] Async_Pending 0
[07/09/2013 12:51:38 1a4c] Download: started
[07/09/2013 12:51:38 1a4c] Download: result: Async_Succeeded
[07/09/2013 12:51:38 1710] Dispatch: SOURCE_DOWNLOAD
[07/09/2013 12:51:38 1710] [WaitForVersionDownload] Async_Succeeded 1028
[07/09/2013 12:51:38 1710] [CompareVersions]
[07/09/2013 12:51:38 1710] [CompareVersions] Client info:
[07/09/2013 12:51:38 1710] [CompareVersions]     Client = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     Connection = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     LCID = 1033
[07/09/2013 12:51:38 1710] [CompareVersions] Server info:
[07/09/2013 12:51:38 1710] [CompareVersions]     ClientRequired_MacOS = 1.0.1069.0
[07/09/2013 12:51:38 1710] [CompareVersions]     ClientRequired_Win32 = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     ClientRequired_Win64 = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     Client_MacOS = 1.0.1069.0
[07/09/2013 12:51:38 1710] [CompareVersions]     Client_Win32 = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     Client_Win64 = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions]     Server = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] versionServer   = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] versionRequired = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] versionOffered  = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] versionClient   = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] connectServer   = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] connectClient   = 6.1.8800.16400
[07/09/2013 12:51:38 1710] [CompareVersions] connector version is OK
[07/09/2013 12:51:38 1710] [Cleanup]
[07/09/2013 12:52:19 153c] Service: Client Update service stopping.
[07/09/2013 12:52:19 153c] ClientUpdate: DoStop() entry
[07/09/2013 12:52:19 1710] Dispatch: SOURCE_MAIN
[07/09/2013 12:52:19 1710] [idle]
[07/09/2013 12:52:19 1710] ClientUpdate: Main stopping
[07/09/2013 12:52:19 153c] ClientUpdate: Main thread ended normally
[07/09/2013 12:52:19 153c] ClientUpdate: DoStop() exit
[07/09/2013 12:52:19 153c] Service: Client Update service stopped.
[07/09/2013 12:52:19 153c] ***-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-***
[07/09/2013 23:40:35  f50] ***-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-***
[07/09/2013 23:40:35  368] Service: Client Update service started.
[07/09/2013 23:40:35  368] ClientUpdate: DoStart() entry
[07/09/2013 23:40:35  368] ClientUpdate: started main thread
[07/09/2013 23:40:35  368] ClientUpdate: DoStart() exit
[07/09/2013 23:40:35 1cc4] ClientUpdate: Main starting
[07/09/2013 23:40:35 1cc4] Events: Created PRS event
[07/09/2013 23:40:35 1cc4] Events: Unable to adjust PRS event security, GLE=0x0
[07/09/2013 23:40:35 1cc4] [DelayStartup]
[07/09/2013 23:40:35 1cc4] [startup] Server INTELHDSERVER
[07/09/2013 23:40:35 1cc4] [startup] Client LCID 1033
[07/09/2013 23:40:35 1cc4] [startup] Folder C:\ProgramData\Microsoft\Windows Server\Data\Update\
[07/09/2013 23:40:35 1cc4] [Cleanup]
[07/09/2013 23:40:35 1cc4] [idle]
[07/09/2013 23:42:36 1cc4] [idle]
[07/09/2013 23:42:36 1cc4] [CheckVersion]
[07/09/2013 23:42:36 1cc4] [CheckVersion] Source: connect/default.aspx?get=VersionInfo.xml&LanguageId=1033&64bit=0
[07/09/2013 23:42:36 1cc4] [CheckVersion] Target: C:\ProgramData\Microsoft\Windows Server\Data\Update\VersionInfo_1.xml
[07/09/2013 23:42:36 1cc4] [WaitForVersionDownload] Async_Pending 0
[07/09/2013 23:42:36 1b28] Download: started
[07/09/2013 23:42:36 1b28] Download: result: Async_Succeeded
[07/09/2013 23:42:36 1cc4] Dispatch: SOURCE_DOWNLOAD
[07/09/2013 23:42:36 1cc4] [WaitForVersionDownload] Async_Succeeded 1028
[07/09/2013 23:42:36 1cc4] [CompareVersions]
[07/09/2013 23:42:36 1cc4] [CompareVersions] Client info:
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Client = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Connection = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     LCID = 1033
[07/09/2013 23:42:36 1cc4] [CompareVersions] Server info:
[07/09/2013 23:42:36 1cc4] [CompareVersions]     ClientRequired_MacOS = 1.0.1069.0
[07/09/2013 23:42:36 1cc4] [CompareVersions]     ClientRequired_Win32 = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     ClientRequired_Win64 = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Client_MacOS = 1.0.1069.0
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Client_Win32 = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Client_Win64 = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions]     Server = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] versionServer   = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] versionRequired = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] versionOffered  = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] versionClient   = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] connectServer   = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] connectClient   = 6.1.8800.16400
[07/09/2013 23:42:36 1cc4] [CompareVersions] connector version is OK
[07/09/2013 23:42:36 1cc4] [Cleanup]
[07/09/2013 23:43:31  f50] Service: Client Update service stopping.
[07/09/2013 23:43:31  f50] ClientUpdate: DoStop() entry
[07/09/2013 23:43:31 1cc4] Dispatch: SOURCE_MAIN
[07/09/2013 23:43:31 1cc4] [idle]
[07/09/2013 23:43:31 1cc4] ClientUpdate: Main stopping
[07/09/2013 23:43:31  f50] ClientUpdate: Main thread ended normally
[07/09/2013 23:43:31  f50] ClientUpdate: DoStop() exit
[07/09/2013 23:43:31  f50] Service: Client Update service stopped.
[07/09/2013 23:43:31  f50] ***-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-***
[07/09/2013 23:50:36 1338] ***-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-^-***
[07/09/2013 23:50:36 12d0] Service: Client Update service started.
[07/09/2013 23:50:36 12d0] ClientUpdate: DoStart() entry
[07/09/2013 23:50:36 12d0] ClientUpdate: started main thread
[07/09/2013 23:50:36  d28] ClientUpdate: Main starting
[07/09/2013 23:50:36 12d0] ClientUpdate: DoStart() exit
[07/09/2013 23:50:36  d28] Events: Created PRS event
[07/09/2013 23:50:36  d28] Events: Unable to adjust PRS event security, GLE=0x0
[07/09/2013 23:50:36  d28] [DelayStartup]
[07/09/2013 23:50:36  d28] [startup] Server INTELHDSERVER
[07/09/2013 23:50:36  d28] [startup] Client LCID 1033
[07/09/2013 23:50:36  d28] [startup] Folder C:\ProgramData\Microsoft\Windows Server\Data\Update\
[07/09/2013 23:50:36  d28] [Cleanup]
[07/09/2013 23:50:36  d28] [idle]
[07/09/2013 23:52:36  d28] [idle]
[07/09/2013 23:52:36  d28] [CheckVersion]
[07/09/2013 23:52:36  d28] [CheckVersion] Source: connect/default.aspx?get=VersionInfo.xml&LanguageId=1033&64bit=0
[07/09/2013 23:52:36  d28] [CheckVersion] Target: C:\ProgramData\Microsoft\Windows Server\Data\Update\VersionInfo_1.xml
[07/09/2013 23:52:36  d28] [WaitForVersionDownload] Async_Pending 0
[07/09/2013 23:52:36  618] Download: started
[07/09/2013 23:52:36  618] Download: result: Async_Succeeded
[07/09/2013 23:52:36  d28] Dispatch: SOURCE_DOWNLOAD
[07/09/2013 23:52:36  d28] [WaitForVersionDownload] Async_Succeeded 1028
[07/09/2013 23:52:36  d28] [CompareVersions]
[07/09/2013 23:52:36  d28] [CompareVersions] Client info:
[07/09/2013 23:52:36  d28] [CompareVersions]     Client = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     Connection = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     LCID = 1033
[07/09/2013 23:52:36  d28] [CompareVersions] Server info:
[07/09/2013 23:52:36  d28] [CompareVersions]     ClientRequired_MacOS = 1.0.1069.0
[07/09/2013 23:52:36  d28] [CompareVersions]     ClientRequired_Win32 = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     ClientRequired_Win64 = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     Client_MacOS = 1.0.1069.0
[07/09/2013 23:52:36  d28] [CompareVersions]     Client_Win32 = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     Client_Win64 = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions]     Server = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] versionServer   = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] versionRequired = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] versionOffered  = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] versionClient   = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] connectServer   = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] connectClient   = 6.1.8800.16400
[07/09/2013 23:52:36  d28] [CompareVersions] connector version is OK
[07/09/2013 23:52:36  d28] [Cleanup]
[07/09/2013 23:53:28 1338] Service: Client Update service stopping.
[07/09/2013 23:53:28 1338] ClientUpdate: DoStop() entry
[07/09/2013 23:53:28  d28] Dispatch: SOURCE_MAIN
[07/09/2013 23:53:28  d28] [idle]
[07/09/2013 23:53:28  d28] ClientUpdate: Main stopping
[07/09/2013 23:53:28 1338] ClientUpdate: Main thread ended normally
[07/09/2013 23:53:28 1338] ClientUpdate: DoStop() exit
[07/09/2013 23:53:28 1338] Service: Client Update service stopped.
[07/09/2013 23:53:28 1338] ***-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-v-***
 Share
