Controllers are running latest firmware. Stablebit Scanner will not pull SMART data from any drive. When attempting to "Show S.M.A.R.T..." in StableBit Scanner the following message is displayed: "Using non-manufacturer specific interpretation rules."
Running smartctl will pull SCSI and ATA SMART data without issue (example of disk 17 shown):
C:\Program Files\smartmontools\bin>smartctl /dev/pd17 -x
smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-2019] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: WDC
Product: WD4001FFSX-68JDB
Revision: 4321
Compliance: SPC-3
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
Logical Unit id: 0x50014ee65a754049
Serial number: <redacted>
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Tue Sep 14 17:52:01 2021 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
Read Cache is: Enabled
Writeback Cache is: Disabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 31 C
Drive Trip Temperature: 60 C
Manufactured in week 04 of year 2010
Specified cycle count over device lifetime: 256
Accumulated start-stop cycles: 0
Read defect list: asked for grown list but didn't get it
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 0 0.000 120054
write: 0 0 0 0 0 0.000 186
Non-medium error count: 0
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background short Completed - 36193 - [- - -]
Long (extended) Self-test duration: 65535 seconds [1092.2 minutes]
scsiPrintBackgroundResults Failed [scsi response fails sanity test]
Protocol Specific port log page for SAS SSP
relative target port id = 1
generation code = 0
number of phys = 1
phy identifier = 0
attached device type: expander device
attached reason: power on
reason: unknown
negotiated logical link rate: phy enabled; 6 Gbps
attached initiator port: ssp=0 stp=0 smp=1
attached target port: ssp=0 stp=0 smp=1
SAS address = 0x500a098006055e1e
attached SAS address = 0x500a09800610033f
attached phy identifier = 23
Invalid DWORD count = 0
Running disparity error count = 0
Loss of DWORD synchronization = 0
Phy reset problem = 0
relative target port id = 2
generation code = 0
number of phys = 1
phy identifier = 1
reason: unknown
SAS address = 0x500a098006055e1d
attached SAS address = 0x500a0980060feeff
C:\Program Files\smartmontools\bin>smartctl -d sat -A /dev/pd17
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 197 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 149 138 021 Pre-fail Always - 11550
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 165
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 032 032 000 Old_age Always - 49885
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 159
16 Unknown_Attribute 0x0022 119 081 000 Old_age Always - 2098043337661
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 153
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 746
194 Temperature_Celsius 0x0022 121 091 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
the1337moderate
System Specs:
