Is there a way to control which disks in a pool are to be used for duplication?
I have a large external hard drive that I'd like to use purely for duplicating certain folders from my DrivePool. Is there a way to control this? Ideally, since it's external, I'd like to be able to remove the drive when it's not needed (e.g., when I'm not copying files to the pool).
You could use Hierarchical Pools. Say you have disks A, B internal and C is the external one. You can then:
1. Create a Pool Q consisting of A and B, no duplication
2. Create a Pool R consisting of C, no duplication (*)
3. Create a Pool P consisting of Pools Q and R, x2 duplication.
However, I don't think there is a good way to deal with temporarily removing drives. AFAIK, if you then (physically) remove/disconnect drive C, DP will put Pool P in read-only mode. May be what you are looking for but I'm not sure that will always work out well. Moreover, is that a USB connected drive? AFAIK, using USB-connected drives is not considered best practice and IIRC, it has led to problems, including data loss, due to connections over USB sometimes dropping for a bit (which I think is still within spec for USB).
(*) you could also create Pool P with Q and C, so without the intermediary step of Pool R but I think it makes it a bit harder to manage when removing/adding.replacing drives.
Umfriend, I'm try to do something similar just with a 4 bay DAS. I have 4 - 12TB drives. A, B, C and D. I want A and B pooled no duplication and C and B pooled no duplication aswell. But I want C and D be a duplication of A and B so I have a better idea what drives are doing what.
So I think I need to create pool E = A + B no duplication and F = C + D no duplication.
Then create pool G = E + F with duplication.
So if above is correct then which pool do I want to write to? My guess is write my files to pool G or maybe E?. If that's correct then can I hide the other pools somehow so I see only the pool I need to write to.
Thanks in advance
Ah, you would write files to G:\. DP will save two duplicates to E and F. Each of E and F would divide single instances to A+B and C+D respectively.
Do not write to E or F. You can, but those files will only be part of Pool E (or F) and not be duplicated. Much like writing to a drive directly outside of the hidden PoolPart.* folders, those would not be part of any Pool.
Thank you for the help, I have it all set up and working perfectly.
