I made the mistake of allowing Windows to update last night. When I got up this morning one of my disks said it was missing from my Drivepool. I had no previous issues or errors with this drive. I tried to bring up Scanner but it said I needed to enter a license. I entered my license code and it said it was accepted, but didn't change. I'm at a bit of a loss on what to do about the license.
I noted that both Drivepool and Scanner have updates, but I didn't get any prompt to download/install updates or anything.
As for the drive, it looks like the partition info is corrupt. I can mount it on another machine, but it want's to initialize it, but it doesn't work. A couple drive utils report a bunch of read errors, but can't find a partition to try to recover files from.
Dizzy
