Looking to move from Drive Bender - best way of handling?
I bought two extra drives for a new server build.  I'm not sure if I should set up a new server with the new drives and then start transferring files from the old drives?  Or is there a quicker way of transitioning?  I'm thinking no but figured it made sense to ask just in case.
Well, if you're moving from DriveBender, then it may be simple.
You may be able to get away with just adding the drives to DrivePool, and moving the contents from the "{xxxxxxx}" folders to the hidden "PoolPart.xxxxxx" folders.
But you are right, the "long way" is almost always the most reliable method. Better safe than sorry, right?
