CC88 3 Posted September 11, 2018 Share Posted September 11, 2018 Wondering if anyone has had this error when attempting to remove a drive from a pool...? Quote Link to post Share on other sites
0 Solution Christopher (Drashna) 623 Posted September 12, 2018 Solution Share Posted September 12, 2018 Yup, it's an issue with the deployment on 32 bit systems. This should be fixed here: http://dl.covecube.com/DrivePoolWindows/beta/download/StableBit.DrivePool_2.2.3.939_x86_BETA.exe Quote Link to post Share on other sites
0 CC88 3 Posted September 12, 2018 Author Share Posted September 12, 2018 4 hours ago, Christopher (Drashna) said: Yup, it's an issue with the deployment on 32 bit systems. This should be fixed here: http://dl.covecube.com/DrivePoolWindows/beta/download/StableBit.DrivePool_2.2.3.939_x86_BETA.exe Thanks for the quick reply. Are there any catches to using/installing a BETA verion? I think, I read in a different thread you said they are quite stable and used quiet often. Once the next official release is available, can the BETA version be updated to the official release in the normal ways? Thanks. Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted September 19, 2018 Share Posted September 19, 2018 Nope, you should be fine to install this beta. And yes, it will get the notification when the next stable version is out. Quote Link to post Share on other sites
0 CC88 3 Posted September 20, 2018 Author Share Posted September 20, 2018 Sounds good and thanks for confirming! Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted September 20, 2018 Share Posted September 20, 2018 Welcome! Quote Link to post Share on other sites
CC88 3
