remeasuring and missing disks after system reboot since bitlocker encryption
Hello there,
 I have the following problem: After I encrypted all my pooled drives DrivePool remeasures the whole pool after a system reboot. My system is a Windows 8.1 Pro machine and everything worked well until I encrypted the drives. The encryption runs via bitlocker and the data drives are unlocked with the autounlock feature of bitlocker.
To troubleshoot the problem I already delayed the start of the service, but the problem persists. Sometimes some disks are not even found after rebooting.
Is there anything I can do to change this?
cheers
Check these topics for some info on Bitlocker and Drivepool.  I believe the correct order is to Bitlock the individual drives, then add them to the pool.  You have to unlock them after every boot - I'm not certain if auto-unlock qualifies.  Normally Drivepool monitors for drive unlocks while waiting for pool parts to arrive.
7 hours ago, Christopher (Drashna) said:
Are you using the automatic unlock option for the disks?
If not, make sure that you haven't disabled "BitLocker_PoolPartUnlockDetect" in the advanced settings.
If you have, that is why you're having issues.
I do use autounlock for the drives. I did encrypt the system drive first for testing and everything seemed to work.
I didn't disabled the setting. Before encrypting 30TB of storage, I read every Bitlocker regarding thread...so no, thats not why I am having issues.
Any other idea? Reinstalling DrivePool maybe?
Thanks for the answers.
