Saw Clouddrive throwing this error a few days after adding a FTP drive, no actual data on it currently, but it's pinning 76.4 MB and Caching 75.4MB.
I/O error
Cloud drive My_FTP (E:\) is having trouble uploading data to FTP.
Error: Not enough data.
This error has occurred 1,937 times.
Make sure that you are connected to the Internet and have sufficient bandwidth available
Your data will be cached locally if this persists.
The machine Clouddrive is on is connected to a 250/10 Mbit internet connection over a VPN, which is working fine. It was used in the same configuration to setup the FTP cloud drive.
The only part of this I can see that could be responsible, is a "To upload" amount of 168 KB, which doesn't seem to want to go 'up' to the FTP server. I have yet to toss any files on the drive, but I can if you'd like me to see if it clears the error. I'm unsure if this is a normal result of having a perpetually empty cloud drive, or something else. I'm not worried about it either way, unless it's actually connecting to the FTP server 1,937 times.
Edit: in the process of writing this post, the error count has risen another 4, to 1,941 total. Seems like it's trying vigorously but cannot due to some limitation.
Jaga
I/O error Cloud drive My_FTP (E:\) is having trouble uploading data to FTP. Error: Not enough data. This error has occurred 1,937 times. Make sure that you are connected to the Internet and have sufficient bandwidth available Your data will be cached locally if this persists.The machine Clouddrive is on is connected to a 250/10 Mbit internet connection over a VPN, which is working fine. It was used in the same configuration to setup the FTP cloud drive.
8 answers to this question
