APoolTodayKeepsTheNasAway Posted April 13, 2018 Posted April 13, 2018 Hi, I have a 3tb drive in a cheap vantec 1 drive enclosure, and it just seemed weird to me that with Crystal Disk Info as well as WD Data Lifeguard, Smart data was readable, whereas in Scanner, it says S.M.A.R.T. check is not available. This seems especially odd to me considering that I have a 2TB portable, external wd disk and its values are able to be read yet it operates at USB 2 speeds and without UASP unlike the other enclosure. Is there a setting I've looked over? Quote
Christopher (Drashna) Posted April 16, 2018 Posted April 16, 2018 Could you make sure that you're using this version? http://dl.covecube.com/ScannerWindows/beta/download/StableBit.Scanner_2.5.2.3156_BETA.exe Also, do this: http://wiki.covecube.com/StableBit_Scanner_Advanced_Settings Find the "Smart" section and check the "NoWmi" option. If that doesn't work, then find the "Unsafe" option in DirectIo. Quote
APoolTodayKeepsTheNasAway Posted April 16, 2018 Author Posted April 16, 2018 1 hour ago, Christopher (Drashna) said: Could you make sure that you're using this version? http://dl.covecube.com/ScannerWindows/beta/download/StableBit.Scanner_2.5.2.3156_BETA.exe Also, do this: http://wiki.covecube.com/StableBit_Scanner_Advanced_Settings Find the "Smart" section and check the "NoWmi" option. If that doesn't work, then find the "Unsafe" option in DirectIo. I was using the latest Stable version from the website. Using this version, from the start, smart data is readable without the rest of the steps. Quote
